Bug: Some command info extends past the command line input
I’ve come across a small visual glitch with how the command line displays What:
And a similar thing with _PushPull:
It seems that when any text overflows the line, then the command line input area increases by however many lines needed to fully display the information, similar to how PushPull or other commands with CLI options would expand upward, so it’s curious that this logic is not applied to What, and probably other commands that I haven’t tested out.
As for why the PushPull info is overflowing, that’s pretty odd since there is more than enough space to the right of the text.
System Info
Rhino 8 SR5 2024-2-15 (Rhino 8, 8.5.24046.03001, Git hash:master @ e8229c556c788288cab06127611336f1d7162c19)
License type: Educational, build 2024-02-15
License details: Cloud Zoo
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 16GB)
.NET 7.0.0
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 7-8-2020 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 3070 Laptop GPU (NVidia) Memory: 8GB, Driver date: 12-6-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 546.33
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-6-2023
Driver Version: 31.0.15.4633
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Users\Anto\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\Bella (813de3fb-18eb-405f-bfcd-b0b4d3da91fb)\23.6.0.0\bella_rhino.rhp “Bella” 23.6.0.0
C:\Program Files\Cyberstrak\R7\CS_ModelingPlugIn.rhp “Cyberstrak Modeling PlugIn”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.5.24046.3001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.5.24046.3001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.5.24046.3001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.5.24046.3001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.5.24046.3001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.5.24046.3001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.5.24046.3001
And a similar thing with Trim:
I guess this is a classic issue of responsive UI design where solutions aren’t always as straightforward as one might think: for example, a scenario where simply programming the input/info window area to vertically extend to make sure it doesn’t overflow the horizontal width dictated by the command panel would result in some increasingly wacky behaviour as the width of the command panel decreases.
