sending the file to support
Rhino 8 SR16 2025-1-21
in layout
in pdf
Hi Ivan -
There is no need to post here as well then.
Apart from that, from these images, it’s impossible to tell which type of output that you chose when printing. If you are printing to vector, that is the expected behavior.
how come? when i choose rendered for detail view i want output rendered (rastered). problem is some detail views behave well and some are turned into wireframes. vector can be used to curves and surface edges in wireframe or technical.
Sorry, yes, that should work.
It looks like that detail only contains curves with curve piping on.
I’ll get that on the list.
Thanks,
yes somehow it looks like rhino tries to be intelligent and determine if vector method can be used when only vectorpossible elements are used in a frame…
Hi Ivan -
I would put that the other way around. Rhino doesn’t “see” what is in a viewport. It only knows which objects are displayed. Rhino needs to try to be intelligent to also find out that this curve doesn’t look like a curve to humans.
→ RH-86283 Print: Fake2D Draws Shaded Detail in Wireframe
