If I change the settings on the Surface param node to reparameterized, and then reference in the surface, it doesn’t reparameterize it initially. Removing the reparamaterized setting and then adding back in does. Haven’t checked with other geometry types.
Edit: Well, this is odd. I can’t replicate this. Should have cherished the moment.
