This bug was present since many years with older Rhino versions and only happened on rare occasions, but recently it really started to get too disturbing as basically half of the '_CPlane _Elevation command on my Rhino 7 end up destroying the original orientation of the current CPlane and instead rotate it at 90 degrees in a random direction. The one solution I’m forced to use is to build a plane object in the center of the Cplane, then move it vertically at the desired distance, then run the '_CPlane _Object command, then delete the plane object, but this is slow and requires more mouse clicks.
I run the latest Rhino 7 SR16 (7.16.22039.15001, 2022-02-08) Commercial.
Here is a video showing the bug in its full glory:
