Bug: SelectionPoint()
We found a bug regarding SelectionPoint() method
The method works properly on vertical, horizontal surfaces but it sometimes fails on tilting surfaces.
EDIT: It also works with polysurface but not with surface group.
Please, read the following thread:
Hi @onrender,
Can you post a model, some sample script code, and precise instruction on how to repeat the problem you are seeing?
– Dale
Hi Dale,
Please, click on the red area of the grouped surfaces. Same behaviour on the polysurface but I could not apply the red material. The selection point will be off the projection.
Code sample:
import Rhino
import scriptcontext
# Select surface or polysurface:
obj_ref = rs.GetObject("Surface to move", rs.filter.surface, True, False, None, True)
if obj_ref.SelectionMethod() == Rhino.DocObjects.SelectionMethod.MousePick:
    clickPoint = rs.AddPoint(obj_ref.SelectionPoint())
test.3dm (88.9 KB)
@dale, I’ll add this to youtrack and will investigate.
