Bug second screen panel ghp
Hi everyone,
from a lot of time I have this issue, whenever ghp panel is on the second screen, and for just a moment you drag the panel from a screen to another, then when you try to for istance delete a component in grasshopper or doing ctrl-z, or ctrl-y, is executing as a command in rhino.
Is anyone solved the problem?
Hi Lorenzo,
I can’t reproduce your problem - provided I don’t shift focus outside the gh window after moving it, everything works as expected. Could you publish the results of the Rhino _SystemInfo command and maybe a video screencap of how the problem occurs?
Regards
Jeremy
