I apologize for not providing context earlier. Here is a script where the error occurs. This error appears in several of my scripts that previously worked perfectly, and I haven’t changed anything in these scripts. Even more strangely, the error appears in certain Rhino files but not in all of them.
Thank you for your understanding.
Best regards,
#! python3
## Auteur : Yannick Guillec
## Date : 19/02/2025
import datetime
import random
import scriptcontext as sc
scale = 1
## Fonction ##
def numberCoupe():
dateTime = datetime.datetime.now()
number = random.randint(10, 99)
numberCoupe = dateTime.strftime("%Y%m%d%H%M%S")
numberCoupe = numberCoupe+str(number)
return numberCoupe
def scaleZDT(point):
rs.UnselectAllObjects()
allObjects = rs.AllObjects()
ZoneDeTravail = [obj for obj in allObjects if rs.GetUserText(obj, "Scale") is not None]
if not ZoneDeTravail:
print("Aucun objet avec l'attribut Scale trouvé.")
for rect in ZoneDeTravail:
if rs.PointInPlanarClosedCurve(point, rect):
rs.SelectObject(rect)
scale = rs.GetUserText(rect, "Scale")
return scale
print("Le point n'est à l'intérieur d'aucun rectangle.")
scale = 1
return scale
def creationCoupe(point, vector, scale, vectorPerpendicular, texte, angle, numberCoupe):
scale = float(scale)
longueur = 20*scale
base = 2*scale
sommet = 5*scale
couleur = (255, 255, 0) #Jaune
hautSymbole = rs.PointAdd(point, rs.VectorScale(vector, longueur / rs.VectorLength(vector)))
lineCoupe = rs.AddLine(point, hautSymbole)
midPointCoupe = rs.CurveMidPoint(lineCoupe)
trianglePoint1 = rs.PointAdd(midPointCoupe, rs.VectorScale(vectorPerpendicular, base / rs.VectorLength(vectorPerpendicular)))
trianglePoint2 = rs.PointAdd(hautSymbole, rs.VectorScale(vectorPerpendicular, base / rs.VectorLength(vectorPerpendicular)))
midLine = rs.AddLine(midPointCoupe, hautSymbole)
midPointMidLine = rs.CurveMidPoint(midLine)
trianglePoint3 = rs.PointAdd(midPointMidLine, rs.VectorScale(vectorPerpendicular, sommet / rs.VectorLength(vectorPerpendicular)))
triangle = rs.AddPolyline((trianglePoint1,trianglePoint2,trianglePoint3,trianglePoint1))
midTexte = rs.AddLine(midPointCoupe, point)
midPointMidTexte = rs.CurveMidPoint(midTexte)
centreTexte = rs.PointAdd(midPointMidTexte, rs.VectorScale(vectorPerpendicular, 3.46*scale / rs.VectorLength(vectorPerpendicular)))
texte = rs.AddText(texte, centreTexte, 5, None, 0, 131074)
dimZDT = sc.doc.Objects.Find(texte)
dimZDT.Geometry.DimensionScale = float(scale)
dimZDT.CommitChanges()
rs.RotateObject(texte, centreTexte, angle, axis=None, copy=False)
rs.ObjectColor((triangle, lineCoupe), couleur)
rs.SetUserText(triangle, "ID Coupe", numberCoupe)
rs.SetUserText(lineCoupe, "ID Coupe", numberCoupe)
rs.SetUserText(texte, "ID Coupe", numberCoupe)
rs.DeleteObjects((midLine,midTexte))
if rs.IsLayer("COTEX"):
rs.ObjectLayer((triangle, lineCoupe, texte), "COTEX")
## Fonction ##
## Main ##
numberCoupe = numberCoupe()
texteCoupe = rs.GetString("Nom de la coupe ","1")
startPoint = rs.GetPoint("Sélectionnez le point de départ")
endPoint = rs.GetPoint("Sélectionnez le point d'arrivée", startPoint)
line = rs.AddLine(startPoint, endPoint)
midPoint = rs.CurveMidPoint(line)
scale = scaleZDT(midPoint)
vector = rs.VectorCreate(startPoint, endPoint)
vectorPerpendicular = rs.VectorCrossProduct(vector, (0, 0, 1))
vectorZero = rs.VectorCreate(startPoint, (startPoint[0]+10,startPoint[1],startPoint[2]))
angle = rs.VectorAngle(vectorZero, vector)
if startPoint[1] > endPoint[1]:
angle = 180-angle
if angle > 45:
if angle < 135:
angle = angle -90
creationCoupe(startPoint, vector, scale, vectorPerpendicular, texteCoupe, angle, numberCoupe)
vector = rs.VectorReverse(vector)
creationCoupe(endPoint, vector, scale, vectorPerpendicular, texteCoupe, angle, numberCoupe)
rs.DeleteObject(line)
## Main ##
