BUG - Script Editor - Can't Set Input Access
After recent WIP I can’t set the input access type from anything other than “Item” on the new script editor component.
Does not change when clicked:
Curious if this is repeatable for anyone else?
Thank you all!
@eirannejad
Same here.
Same. The script editor (and old GHPython component in Rhino 8) has taken a serious downturn starting with the 5th Sept release.
@eirannejad fyi I can’t repeat that here. In current dujour all seems to behave normally.
8.0.23251.10305, 2023-09-08
Same thing here.
It’s been fixed. Will be available in tomorrow’s build. We did a major change on how the parameter are setup on the new scripting components. I’m actually glad not more is broken :smiley:
Thanks @eirannejad ! Looking forward to it!
