I noticed that the file size of a file which was originally 55,3 MB nearly doubled after saving it in Rhino 9 BETA. Then I changed the state of the following advanced option, restarted Rhino 9 BETA multiple times, but the file size remains big (non-compressed) when I save it.
Perhaps the compression is not working on my PC anymore?
Does the file contain any textures, particularly photo texturing? I don’t know the details but my understanding is there are some changes in texture storage in V9 possibly including defaults. Again, I don’t know the details.
Hi @Rhino_Bulgaria,
Enabling compression doesn’t mean “zip the whole file.” Only certain “things” get compressed, primarily meshes.
– Dale
I think this is the main part to focus on regarding this post:
Why is Rhino 9 making the files bigger? Have you changed how it compresses so it no longer compresses geometry that was compressed in earlier versions, or is it related to other changes?
The 3dm file was primarily made in Rhino 7 and consists multiple image drawings created via the ! _Picture command. Then I opened it in the latest Rhino 9 BETA and saved it as V7 3dm. However, even though I opted for compression (both, from the advanced settings and the “Use compression” tickbox in the Save pop-up window), the file size almost doubles.
Here is the same file opened and then saved in Rhino 7.
Initially, I used only the advanced setting and they didn’t work. Then, I also set the tickbox on “Use compression”. Still saves the file without a compression.
Edit: After I used the following reset of the window layout, the issue is fixed now. In fact, this solution also fixed two unrelated bugs recently. I have no idea how this can fix the lack of compression during saving, but it works properly now. Perhaps some customization of the layout affects other parts of the code.
I should mention that prior the reset of the Window layout, the tickbox on “Use compression” was removed automatically by Rhino 9 BETA and I had to activate it again every single time. But it didn’t compress anyway.
Now that I reset the Window layout, that particular tickbox remains active upon every restart of Rhino. Seems like the bug is solved now.
