Bug? (Rhino8, win11, 4k Display)
Hovering over some icons shows a weird tooltip.
I’m not sure I’m right, but I feel UI response gets faster, and UI gets more organized and cleaned as I install newer service releases. Recently, I started using the MAC version on a MacBook Pro M2. Nearly the same UI is there! My only concern is that the version number seems to go over 8.10 soon :joy:.
Hmm, I don’t see that here… (also Win 11/4K - at 150% display scaling)
The tooltips are still way too fat and always on though - complained since the WIP.
pls run _Systeminfo and post back the results.
@mikity_kogekoge does that happen after you have switched from dark mode?
In any case, I could not reproduce this in our internal build
Yes, it happened after I switched back to the light mode. Actually, I don’t see it anymore. Maybe I was just unlucky.
ISTR there have been reports of similar visual artifacts when switching between light and dark modes.
What ISTR stands for? :melting_face:
Internet jargon for “I seem to recall”…
Related terms:
IIRC - “If I recall correctly”
AFAIK - “As far as I know”
