[bug] Rhino.UI.Dialogs.ShowMessage shows two dialogs for one call
Claude believes there is a bug in Rhino causing duplicating dialog messages in Rhino 9 WIP 9.0.26244.12303, Windows 11:
"A single call to Rhino.UI.Dialogs.ShowMessage(…) puts up two message
windows instead of one: a dark Rhino-themed dialog, with a light
native-styled one stacked on top. Both carry the same text and buttons.
Dismissing one leaves the other on screen.
Call site:
var answer = Rhino.UI.Dialogs.ShowMessage(
    "some text",
    "some text",
    Rhino.UI.ShowMessageButton.YesNo,
    Rhino.UI.ShowMessageIcon.Question);
I hit this from a plugin, in a RhinoApp.Idle callback queued from
RhinoDoc.EndOpenDocument. I logged every layer above the call to rule out
my own code re-entering:
EndOpenDocument fired      1x  (merge=False, reference=False)
my event raised            1x  (1 subscriber)
prompt queued              1x
ShowMessage called         1x
dialogs on screen          2
So it is one invocation producing two windows.
Workaround: calling Eto.Forms.MessageBox.Show directly, owned by
RhinoEtoApp.MainWindowForOwner, shows exactly one dialog and picks up the
Rhino theme correctly."
Hi @Yury_Nasonov1,
Thanks for the detailed report, and for logging each layer of your code. That ruled out re-entrancy on your side.
Here’s what I think is happening. ShowMessage hands the message to Rhino’s themed (Eto) message box. If that themed box reports a failure, Rhino falls back to a native Windows message box. You’re seeing both, which means the themed box was shown, then something threw an exception while it was open, and Rhino treated that as a failure and showed the native box as well. The themed box is never closed on that path, so it stays behind the native one.
To fix the real cause I need to know what’s throwing. Could you add this before your ShowMessage call, reproduce the problem, and post what gets printed to the command line?
Rhino.Runtime.HostUtils.OnExceptionReport += (source, ex) =>
  Rhino.RhinoApp.WriteLine("ExceptionReport: {0}\n{1}", source, ex);
If you’d rather not change code, DebugView running alongside Rhino will also capture it.
In the meantime, calling Eto.Forms.MessageBox.Show with RhinoEtoApp.MainWindowForOwner as the owner, as you’re doing now, is a good workaround.
I’ll log this so the fallback can’t show a second dialog, whatever the underlying cause turns out to be.
Thanks,
— Dale
RH-99089 is fixed in Rhino BETA
