Bug - Rhino PDF
Whenever I print with Rhino PDF selected as the printer, it collapses all of the settings tabs on the print menu. They will all stay expanded during the current Rhino session, but if you close and reopen they are all collapsed.
I haven’t noticed this with other printers being selected. I have noticed this happening all along in V6, just haven’t been able to figure out the culprit.
Thanks,
Don
Hi Don - I see the top expando is zipped up by Rhino PDF and is not by other printers so far, but any of the lower sections are closed up no matter which printer I used last, if I reopen Rhino - is that what you mean?
https://mcneel.myjetbrains.com/youtrack/issue/RH-49684
Yes, I must not have expanded any of the lower ones, when I was testing it, I thought I did, but maybe I just didn’t realize it had closed.
I believe, in V5, whatever sections were expanded stayed that way across sessions. As I recall.
Thanks,
Don
RH-49684 is fixed in the latest Service Release
