I have a file (uploaded to support site) that looks like this in layout (print displace shows similar)
But in PDF output, some the openings are filled in with solid black.
Hi -
If you run the SelBadObjects
command, the green hatch will be selected.
You have two rectangles almost in the same location in the area that gets filled with a black hatch - that throws off the hatch generator and causes the bad object. Delete one of those rectangles to get this to work.
I would suggest running the CheckNewObjects
command and making sure that checking for bad objects is turned on.
Thanks. Is CheckNewobjects persistant?
