For some reason, certain layout items occasionally disappear from the layout list—in this case, almost all of them (compared to the tabs at the bottom). It doesn’t happen regularly, but mostly in projects with a larger number of tabs and active layout groups
The layouts usually disappear after closing and reopening Rhino. Sometimes, they randomly reappear while working. However, saving and reopening the file has no effect on their visibility—once they disappear, reopening the file will not bring them back.
One test:
Create and delete new layout bring other lyouts back…
Thanks for the file. A few questions to help narrow this down:
When the layouts are missing, how was the file opened? Double-clicking the .3dm, Rhino’s recent files list, File > Open in a Rhino that was already running, or dragging the file onto Rhino?
Is the Layouts panel already visible when Rhino starts, or do you open it afterwards?
If you close the Layouts panel and open it again, does the list fill in?
Does it ever happen in a session where you used File > Open from an already-running Rhino?
Note, you can always refresh the list by clicking on an item and then pressing F5.
