Hi @AndyPayne, @kike, and @Gijs ,
After weekly WIP build 8.023234.12305, 2023-08-22 the Bake Content component no longer updates on an input change even if the boolean is set to True.
The boolean needs to be manually toggled false and then back to true for the component to update (and sometimes still does not update)
Notice below where the boundary surface is previewed in green and the Bake component has not updated the Solid Hatch.
Graph Space:
Model Space:
Oddly, setting the boolean to False does not hide the baked content as previous, it now reverts to the last baked position.
Graph Space (Boolean False):
Model Space (Gumball should be where the surface edge is, yet it reverted to the previous bake position):
Thanks!
