I updated to 8.8 yesterday evening now one of my plans that is set to “Arctic” view is not showing some of my items. I am already using “Advanced GPU Lighting”, this wasn’t happening prior to 8.8.
Any assistance would be great as I have a presentation in less than 24-Hours.
only on one object within one block. additionally there are blocks that just contain nurbs and they have the issue aswell. I tried restoring my Arctic view back to default but that didn’t solve it. the only temporary fix i have is to set each objects individual display mode.
Hi Christian -
Can you export a single object that isn’t showing and post or Rhino - Upload to Support that?
Also, please run the Rhino SystemInfo command and copy-paste the output here.
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.0
Computer platform: LAPTOP - Plugged in [79% battery remaining]
Primary display and OpenGL: NVIDIA GeForce RTX 2070 (NVidia) Memory: 8GB, Driver date: 6-1-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 555.99
Primary OpenGL: NVIDIA GeForce RTX 2070 (NVidia) Memory: 8GB, Driver date: 6-1-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 555.99
Secondary graphics devices.
Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 3-16-2020 (M-D-Y).
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-1-2024
Driver Version: 32.0.15.5599
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Users\chris\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Walkie\4.14.0.0\Walkie.rhp “Walkie” 4.14.0.0
C:\Program Files\Enscape\Enscape.Rhino.Plugin-net48\Enscape.Rhino8.Plugin.dll “Enscape.Rhino8.Plugin” 0.0.24138.1238
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino7.rhp “Datasmith Exporter” 5.2.0.0
The problem is in my Layout plan view and it isn’t the clipping planes.
I accidentally sent you the one where i had to set the objects display mode to shaded to see it on plan
I’ll try disabling those plugins and see if it helps.
