Tested on Rhino 8.8 (SR8).
The command FillMeshHole does not appear to work correctly as it did in Rhino 7 (SR37). On filling a hole in the corner of a cube (this is a simple test case), the patch generated overlaps faces around the edge of the hole.
The hole to patch:
As patched by Rhino 8 (not joined):
And joined gives the same result:
I could create a single face bridge and then fill the resulting two separate holes, but this should not be needed as in Rhino 7 the hole is correctly patched
And joined as well:
I would appreciate it if this could be resolved.
Thanks,
Allan
20240705_FillMeshHoleBug.3dm (127.4 KB)
