Start _Revolve.
Select the curve.
Bug:
For the start of the revolve axis, try to select _Between by Shift+hover over Osnaps.
Not available.
When I type _Between or click the _Between icon, it works.
Same in V8.
Start _Revolve.
Select the curve.
Bug:
Not available.
Same in V8.
You could have tried to click the inactivate
option.
BTW, between seems to confuse revolve.
Look at 0:26 in the video.
Of course I tried that, and it works as expected here. I can either use no, one or two times between to define the axis without issues.
A.UI language thing perhaps?
No luck in reproducing it either in German. I also tried the checkboxes vs state buttons: no difference.
To retrace:
Close all Rhino instances.
Start Rhino 8.
Draw a curve.
Start _Revolve from the menu.
Select the curve.
Right mouse button for Enter.
Move the mouse pointer into the Osnap panel.
Hold Shift.
All options are deactivated.
Can’t activate Between.
Start Rhino 8.
Draw a curve.
Pre-select the curve.
Hold Shift.
Options are working.
thanks @Charles for the steps to reproduce, I can now repeat.
Here it seems that bug only bugs once. If I cancel and try the same steps again, things work as expected. I don’t see the differences between pre or post selection though. For me it is only the first time that it bugs out.
RH-97987 Osnap one shot is blocked at first
Now in BETA (9.0.26265.18303, 22.09.2026) it never works.
It got worse.
