[BUG] Reporting a Clipping Plane Rendering Bug in Rhino7
Description
When using a Clipping Plane, I have noticed some Reytraced aesthetics rendering bugs in the viewport.
Hi Alan -
Is this file-specific on your system? If so, we’d need the file.
In any case we’ll also need the SystemInfo.
I have also seen this in various cases; not too difficult to reproduce: cycles-clipping-plane-artifacts.3dm (2.0 MB)
win11 – 7.30.23163.13001, 2023-06-12
win11 – 8.0.23171.14305, 2023-06-20
systeminfo
Rhino 8 SR0 2023-6-20 (Rhino WIP, 8.0.23171.14305, Git hash:master @ b92f7d293d9a041a6f2cbc4ed304f99aba992c88)
License type: Not For Resale Lab, build 2023-06-20
License details: Cloud Zoo
Expires on: 2023-08-04
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 64Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA Quadro P620 (NVidia) Memory: 2GB, Driver date: 6-10-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 536.25
OpenGL Settings
Safe mode: Off
Anti-alias mode: 2x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-10-2023
Driver Version: 31.0.15.3625
Z-Buffer depth: 24 bits
Total Video Memory: 2 GB
C:\Program Files\Rhino 8 WIP\Plug-ins\Commands.rhp “Commands” 8.0.23171.14305
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.0.23171.14305
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.0.23171.14305
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk_ui.rhp “Renderer Development Kit UI”
C:\Program Files\Rhino 8 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.0.23171.14305
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCode\RhinoRoslyn.rhp “RhinoRoslyn” 8.0.23171.14305
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.0.23171.14305
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCode\RhinoCPython.rhp “RhinoCPython” 8.0.23171.14305
C:\Program Files\Rhino 8 WIP\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.0.23171.14305
C:\Program Files\Rhino 8 WIP\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\Program Files\Rhino 8 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 8 WIP\Plug-ins\SectionTools.rhp “SectionTools”
What SystemInfo do not tell you is that:
Viewport resolution size: 6256x3840 (pretty big)
Using two monitors. Rhino was in the main one
Rhino 7 SR30 2023-6-12 (Rhino 7, 7.30.23163.13001, Git hash:master @ f695e494df78377a81b2b95edb99c6067e324b33)
License type: Commercial, build 2023-06-12
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 96Gb)
Primary display and OpenGL: NVIDIA GeForce RTX 3090 (NVidia) Memory: 24GB, Driver date: 4-8-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 531.61
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Render version: 4.6
Driver Date: 4-8-2023
Driver Version: 31.0.15.3161
Total Video Memory: 24 GB
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino7.rhp “Datasmith Exporter” 5.1.1.0
C:\Users\ALanMAttano\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\Bella (813de3fb-18eb-405f-bfcd-b0b4d3da91fb)\23.3.0.0\bella_rhino.rhp “Bella” 23.3.0.0
C:\Users\ALanMAttano\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SubstanceImporter\2.0.3\Substance.Win.rhp “SubstanceImporter” 2.0.3.0
C:\Users\ALanMAttano\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\IntelDenoiser\0.6.4\IntelDenoiser.Windows.rhp “IntelDenoiser.Windows” 0.6.4.0
C:\Users\ALanMAttano\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.3.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.30.23163.13001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoBonusTools.rhp “Rhino Bonus Tools”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.30.23163.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.30.23163.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.30.23163.13001
C:\Program Files\Rhino 7\Plug-ins\export_PDF.rhp “PDF Export” 7.30.23163.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.30.23163.13001
C:\Program Files\Rhino 7\Plug-ins\BlockEdit.rhp “BlockEdit” 7.30.23163.13001
C:\Program Files\Rhino 7\Plug-ins\Calc.rhp “Calc”
Hej -
I’m not sure that there aren’t different issues that are being reported in this thread.
The issue that is visible in the file that JD posted has been fixed, and is possibly related to or the same as your other thread -
As Nathan noted in that other thread, the issue is fixed in Rhino 8 and it’s not possible to back-port this into Rhino 7.
If you are seeing an issue in Rhino 8 with external blocks, please start a new thread and provide the 3dm files that are necessary to reproduce that issue.
Thanks,
@wim If the solution from 8 can’t be “backported” to 7 I would suggest to allow time to fix the issue in a different way in 7, since McNeel will leave a group of loyal customers behind on 7 SR 3X because of the decision to NOT support macOS except for the most recent versions. ClippingPlanes has not worked in Rhino 7 if you rely on Rhino’s render Engine (Cycles). NB Chaos has solved ClippingPlanes in V-Ray 6.
Hi -
We are now focused on fixing issues in Rhino 8 before turning to new features in Rhino 9.
Thanks,
