Bug Report - Wenatchee 5 Build 2014-01-29 - alt H not working
This is a minor issue, but slightly annoying, because i use it a lot. The command to hide an object (alt H) is not working in this build, nor was it working in yesterday’s build (2014-01-28)
hmm… it appears no shortcut using only the option key as a modifier is working in the new layout (the character is instead typed in the command line)
the option key when used in conjunction with other modifier keys does work…
ctrl-option-U for instance
for now, if you need the option key shortcuts (such as option-H for hide), they are working with the heads-up command dialog (Preferences-> Themes-> choose Custom from the drop down list… then select the button ‘Use command dialog options’… open a new window
I can duplicate this. This will be fixed in the next WIP release.
