Always exporting this
AM65 fail Painter mesh.3dm (801.0 KB)
mesh or surface from a simple triangular NURBS surface (created from three boundary curves) produces a file that fails to import properly into Substance Painter (up to version 2026)
and Rizom.
[AM65 fail Painter mesh.3dm|attachment]
The UV coordinates appear inverted (upside-down) when inspected in external tools
Sometimes the geometry is valid inside Rhino but becomes problematic after export. Sometimes is not load in Substance Painter
Expected Result
The mesh should import correctly into Substance Painter with UV orientation matching the original Rhino surface.
Rhino Version Rhino 8 SR30 (8.30.26103.11001, 2026-04-13)
Rhino 8 SR30 2026-4-13 (Rhino 8, 8.30.26103.11001, Git hash:master @ 3ad61623b0ac4561e2f13265580c56a9f50596d8)
License type: Commercial, build 2026-04-13
License details: Cloud Zoo
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 64GB)
.NET 8.0.14
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 5090 (NVidia) Memory: 32GB, Driver date: 3-4-2026 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 595.79
- Secondary monitor attached to adapter port 0
- Windows Main Display attached to adapter port 1
Secondary graphics devices.
Intel(R) UHD Graphics 770 (Intel) Memory: 2GB, Driver date: 10-18-2024 (M-D-Y).
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-4-2026
Driver Version: 32.0.15.9579
Z-Buffer depth: 24 bits
Total Video Memory: 32607 MB
C:\Users\a_mat\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\SubstanceImporter\2.0.7\Substance.Win.rhp “SubstanceImporter” 2.0.7.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.30.26103.11001
C:\Program Files\Rhino 8\Plug-ins\Export_FBX.rhp “Export_FBX”
C:\Program Files\Rhino 8\Plug-ins\import_OBJ.rhp “Import_OBJ” 8.30.26103.11001
C:\Program Files\Rhino 8\Plug-ins\export_OBJ.rhp “export_OBJ” 8.30.26103.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.30.26103.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.30.26103.11001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.30.26103.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.30.26103.11001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.30.26103.11001
