Bug report: sub-object still coloured like selected when not
In some cases the colouring of selected sub-object is not reset after de-selection. I noticed that on subD, no sure if it applies to anything else, haven’t tested.
Steps to reproduce:
  1. In an empty Rhino file, make a subD box (any number of segment):
  2. Set render mode of perspective view to ghosted, and top view to rendered:
  3. In the perspective viewport (ghosted), select a sub-object subD face:
  4. Pan the camera in the top viewport:
  5. Rotate the camera in the perspective viewport:
  6. Click in an empty space of the perspective viewport:
As showed above, the face is still coloured yellow in the perspective viewport, like it was selected, when it’s not. At this point if you move the camera again in the perspective viewport, the face colour will be reset to un-selected.
Rhino 8 SR12 2024-10-8 (Rhino 8, 8.12.24282.07001, Git hash:master @ 2f42167325d83e0da0f3fe08e796c2b26e602bc5)
License type: Commercial, build 2024-10-08
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 31GB)
.NET 7.0.0
Primary display: AMD Radeon™ Graphics (AMD) Memory: 1GB, Driver date: 10-17-2023 (M-D-Y).
> Integrated accelerated graphics device with 3 adapter port(s)
- Windows Main Display attached to adapter port 1
Primary OpenGL: NVIDIA GeForce RTX 3070 Laptop GPU (NVidia) Memory: 8GB, Driver date: 2-22-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 546.80
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 2-22-2024
Driver Version: 31.0.15.4680
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\SimLab\Plugins\SimLab PDF From Rhino\SimLabPDFExporter.rhp “SimLab PDF Exporter”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.12.24282.7001
Hi Felix -
Thanks, it looks like we’ve had this on the list for a while
RH-79311 Display: SubD face highlight in ghosted mode varies
