It is happening with this object only, it was open because of microedges, it got closed using the RemoveAllNakedMicroEdges command.
my version is 7.5.21100.3001
Check to see if there are any non-manifold edges. If there are, Properties will report the object as open.
Hello - please export the object and post the file here.
It was reporting no non-manifold edges too.
I managed to find and fix it doing these steps:
Is there a way that I can send it to you without posting it publicly?
Hello - sure- send to tech@mcneel.com, with a link back here in your comments, and I’ll get it.
