Bug Report - Right Trigonometry
Hi, I was trying out the Right Trigonometry component and I accidentally plugged in a larger value into one of the legs than the hypotenuse. This crashed my file because the math is impossible, but it would be good for a line of error checking that the R value has to be bigger than the leg lengths.
Hi -
Can you post the .gh file and the output from the Rhino SystemInfo command?
There should be a error message when the inputs are not possible:
See below for the systeminfo and grasshopper file. I guess the other caveat is that I’m using this in a script in rhino.inside.revit, not sure if that is a contributing factor to the crashing.
Rhino 8 SR22 2025-8-5 (Rhino 8, 8.22.25217.12451, Git hash:master @ 96429e6361004c775cd83973f2148f3943b5e512)
License type: Commercial, build 2025-08-05
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 64GB)
.NET Framework 4.8.9310.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA RTX A2000 12GB (NVidia) Memory: 12GB, Driver date: 9-12-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 537.42
Accelerated graphics device with 4 adapter port(s)
  • Windows Main Display attached to adapter port #0
  • Secondary monitor attached to adapter port #1
Secondary graphics devices.
Intel(R) UHD Graphics 770 (Intel) Memory: 1GB, Driver date: 6-15-2023 (M-D-Y).
Integrated graphics device with 4 adapter port(s)
  • There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 9-12-2023
Driver Version: 31.0.15.3742
Z-Buffer depth: 24 bits
Total Video Memory: 12282 MB
C:\Program Files\Enscape\Enscape.Rhino.Plugin-net48\Enscape.Rhino8.Plugin.dll “Enscape.Rhino8.Plugin” 4.7.0.57
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.22.25217.12451
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.22.25217.12451
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.22.25217.12451
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.22.25217.12451
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.22.25217.12451
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.22.25217.12451
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.22.25217.12451
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.22.25217.12451
RIR_Right Trigonometry.gh (5.1 KB)
Hi Gordon -
Thanks → RH-89412 Grasshopper: RTrig Hangs Rhino
