Hi All,
hi @stevebaer and @lowell,
with the latest BETA multiline text in text objects gets cropped when the file is saved and reopened.
In this example I put a simple text object in a new empty RH6 instance and filled it with three lines of text.
I don’t know if that helps here but this is the file: TextBug.3dm (28.9 KB)
While talking about the text object:
I don’t think the Text Properties panel is supposed to look like this… When switching on Background > Solid Color, the color field doesn’t appear…
Hi All,
same Problem here, after the last update all multiline texts seem to be damaged. I am talking about thousands of text objects in multiple files… Is there any way to restore this lost data? In the latest BETA all lines except the last one are displayed blank, when saving the whole thing to RH5 the blank lines are deleted and only one line remains.
Hopefully theres some kind of a solution… Working over thousands of room stamps would not be very satisfying…
The damage to multi-line text is done after reading from the file and before displaying.
A fix is being built now.
I don’t know yet when that will be available, but it will be soon
