There is a bug with mouse event listening when the user release the left mouse button outside of Rhino window while in a moving operation.
Steps to reproduce:
- Have an object to move.
- Left click on gumball to move the object, hold the mouse button.
- Move the cursor outside of Rhino window, then release the left mouse button.
- Move back your cursor within Rhino viewport. The gumball is still moving along the mouse.
- Left click in the viewport to position the gumball.
- At this point the camera can’t be rotated anymore with right click.
- To unlock the camera, you must left click somewhere in the viewport.
Expected behaviour: The case in which “mouse-up” is done offscreen is well managed since it seems you can click instead of releasing the held mouse button to finish the repositioning command. However this camera lock thing should no happen at all, and seems it’s related.
PS: This would not happen very often with people using a single monitor, but using multiple monitors it’s quite easy to trigger.
Rhino 8 SR12 2024-10-8 (Rhino 8, 8.12.24282.07001, Git hash:master @ 2f42167325d83e0da0f3fe08e796c2b26e602bc5)
License type: Commercial, build 2024-10-08
License details: Cloud ZooWindows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 31GB)
.NET 7.0.0Computer platform: LAPTOP - Plugged in [100% battery remaining]
Primary display: AMD Radeon™ Graphics (AMD) Memory: 1GB, Driver date: 10-17-2023 (M-D-Y).
> Integrated accelerated graphics device with 3 adapter port(s)
- Windows Main Display attached to adapter port 1
Primary OpenGL: NVIDIA GeForce RTX 3070 Laptop GPU (NVidia) Memory: 8GB, Driver date: 10-15-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 566.03
- Secondary monitor is laptop’s integrated screen or built-in portOpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.6 (primary GPU’s maximum)Anti-alias mode: 4x
Mip Map Filtering: Linear
Anisotropic Filtering Mode: HighVendor Name: NVIDIA Corporation
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-15-2024
Driver Version: 32.0.15.6603
Z-Buffer depth: 24 bits
Total Video Memory: 8 GBRhino plugins that do not ship with Rhino
C:\Program Files\SimLab\Plugins\SimLab PDF From Rhino\SimLabPDFExporter.rhp “SimLab PDF Exporter”Rhino plugins that ship with Rhino
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\RhinoLabsTools.rhp “Rhino Labs Tools”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.12.24282.7001
C:\Program Files\Rhino 8\System\netcore\export_PDF.rhp “PDF Export” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\BlockEdit.rhp “BlockEdit” 8.12.24282.7001
