What I did:
I try to make a seamless Voronoi pattern on a cylinder.
I made a repeatable voronoi pattern on a flat surface, then used Copy Trim to copy the pattern to the cylinder.
Bug:
I got an Invalid surface after Copy Trim due to the seam of the cylinder.
I posted this problem before, and @HS_Kim helped me find a solution.
Now I like to report this as a bug. Is this a bug?
