Hi All,
hi @stevebaer,
the dotted curve in this file DotsWithBlackFrame.3dm (34.4 KB)
appears black-ish when the Layout “Page 1” is printed out… When I print it as PDF and zoom in, i can see the orange layer color with a black frame on each dot. This black frame seems to override the curve color.
This only happens when 0.00 is used in the Linetype setup. If I change the Dots setup to e.g. “0.10, 1.00”, it prints orange without a black frame.
Here are the printed PDFs:
With the original dots Linetype: DotsWithBlackFrame_01.pdf (69.8 KB)
With the adjusted Linetype: DotsWithBlackFrame_02.pdf (36.2 KB)
Thank you!
