Bug - Repeated crash accessing sun panel - urgent
I have experienced repeated crashes when clicking the sun panel.
can someone try to repeat?
Open new file, go to sun panel, turn it on.
N
Hi Nuno -
This is not crashing on my end.
Thanks for the crash reports, I’ll have a developer take a look at those.
Please also post the SystemInfo data from your machine.
Is there a reason this was posted in the “Scripting” category?
@nsgma there were some recent changes to the sun dialog. @johnc is the one who has been making those changes. I created RH-82889 and assigned to him.
@wim
My mistake. I think I had started writing a scripting post before.
System Info below. I am running on remote desktop, can try it without at the moment. However, I have changed the sun in this set up, probably before the last update.
N
`System Info`
Rhino 8 SR10 2024-6-23 (Rhino 8, 8.10.24175.10001, Git hash:master @ 3c2deb221b7add62ed772931e352f501f235f153)
License type: Commercial, build 2024-06-23
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.17
Computer platform: DESKTOP (Hosting Remote Desktop session)
Primary display: Microsoft Remote Display Adapter (Microsoft) Memory: 0MB, Driver date: 6-21-2006 (M-D-Y).
> Remote Desktop display device with 16 connection(s)
- Secondary monitor using connection #0
- Secondary monitor using connection #1
- Windows Main Display using connection #2
Primary OpenGL: NVIDIA GeForce RTX 3060 (NVidia) Memory: 12GB, Driver date: 6-1-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 555.99
> Accelerated graphics device with 0 adapter port(s)
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-1-2024
Driver Version: 32.0.15.5599
Z-Buffer depth: 24 bits
Total Video Memory: 12 GB
C:\Users\Nuno Almeida\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.3.0
C:\Users\UserName\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\AMDDenoiser\0.5.3\AMDDenoiser.Windows.rhp “AMDDenoiser.Windows” 0.5.3.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.10.24175.10001
C:\Program Files\Rhino 8\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.10.24175.10001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.10.24175.10001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.10.24175.10001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.10.24175.10001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.10.24175.10001
C:\Program Files\Rhino 8\Plug-ins\BlockEdit.rhp “BlockEdit” 8.10.24175.10001
C:\Program Files\Rhino 8\Plug-ins\NamedPositions.rhp “Named Position”
This bug is already fixed. See RH-82741.
Thanks John
But it seems I am in the latest released version
Any idea when the fix will be shipped?
N
on second thoughts, I am not sure it is the same. I have widened the window unreasonably and it still happens. maybe just unluck?
Hi @nsgma,
I’m a bit confused about how you managed to get 8.10 because it’s not released yet. Did someone send you a special link to a pre-release version?
John
Yes, I did.
