Bug: Remeshing after open mesh options and close without changes
if I go to the global mesh settings, look at the details and close the options, than the whole meshes are recalculated. Do it again, open the mesh options and close the options without any change β†’ remeshing. It cause a strong slow down for working on complex models and I suppose so it can be fixed. :wink:
Best-
Micha
Yes, I can repeat that.
I’ll log it as a Regression as V7 does not do that.
It did that at one point a long time ago IIRC, I seem to recall having reported it.
https://mcneel.myjetbrains.com/youtrack/issue/RH-73817/Opening-mesh-settings-in-Options-is-triggering-a-remesh
Well @Helvetosaur , I’m bigger than you so maybe they’ll listen this time!
5 posts were split to a new topic: Custom object mesh triggers remesh even when no changes have been made
