Bug: RailRevolve History Replay
You can’t move a RailRevolve without the profile going crazy.
Test file:
RailRevolveBug.3dm (87.8 KB)
Repro Steps (each input to the command is labeled on separate layers):
Grab the profile, rail, and axis curves and move them to the right:
The history replay flips the profile curve halfway through the revolve:
Hi Eric - I see this - I guess it is because the axis line is not really an input object - just the two points you place using this as a reference. Revolve was tweaked to habndle this - you can move an axis curve that was snapped to to establish the axis, I imagine RailRevolve can get a similar massage.
RH-81993 RailRevolve - use an axis curve with History
BlendSrf history replay is fairly stable with RailRevolve, but then RailRevolve is missing the axis … :man_facepalming:
I can’t win.
