Bug R8 Mac- Custom Menus dissapear on relaunch
Q1 - Still don’t know difference between “default” library and “defaultmac” library, although I have figured out they are not the same and menus created in defaultmac don’t show up in “default” so I just create hem all in “default”
Once I figured that out (and still don’t understand why), I’ve managed to create 3 top level menus: utility, align and select by,
These all have separators, sub menus, etc and they work fine.
Until I quit or it crashes.
On relaunch (even wiith a quit with no documents open at all) the menus vanish leaving just the built in defaults
The only way to get them back is open the menus editor, (and the previously created menus do NOT show up), create a new menu (doesn’t even have to have any items in it) and close the menus dialog.
Then the previously created menus show up, followed by the just created empty menu and will remain intact until the next quit or crash.
Then the cycle repeats (with the New New Menu following the previously created “real” menus and the lother previously created “new” menus just to get the menus to show up.
Over the course aof a couple test these “placeholder” menus used just for getting them to show up in the first place keep growing and eventually after I notice it I’ll open menus and delete those, which does work.
Sysinfo below:
Rhino 8 SR1 2023-11-21 (Rhino 8, 8.1.23325.13002, Git hash:master @ 8a4a437248efac5d9cb04d3904481b83e4c23a64)
License type: Commercial, build 2023-11-21
License details: Cloud Zoo
Apple macOS Version 12.6.2 (Build 21G320) (Physical RAM: 80Gb)
Mac Model Identifier: MacPro5,1
Language: en-US (MacOS default)
.NET 7.0.0
Metal GPU Family Apple 0
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
AMD Radeon RX 580 (8 GB)
DELL SE3223Q (3840 x 2160 @ 60.00Hz)
USB devices
GN Audio A/S: Jabra Engage 75
Kensington: Kensington Slimblade Trackball
3Dconnexion : SpacePilot PRO
Apple, Inc: Apple Keyboard
Broadcom Corp.: Bluetooth USB Host Controller
Bluetooth devices
None
Third party kernel extensions
as.vit9696.Lilu (1.6.2) 264B15BE-8923-3A33-A9F5-8F0FFBB80595
as.vit9696.WhateverGreen (1.6.3) 9599C0FC-6144-3136-854C-C15FFF63706F
com.khronokernel.FeatureUnlock (1.1.2) 46C7C044-AE43-378A-8E50-F24BA68705DA
com.AmbrosiaSW.AudioSupport (4.1.4) no UUID
Third party plugins
/Library/Frameworks/3DconnexionClient.framework/Versions/A/3DconnexionClient
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftCoreData.dylib
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftCloudKit.dylib
/usr/lib/swift/libswiftContacts.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftNetwork.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
/usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.1.23325.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.1.23325.13002
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.1.23325.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.1.23325.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.1.23325.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.1.23325.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.1.23325.13002
/Applications/Rhino 8.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 8.1.23325.1002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.1.23325.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 8.1.23325.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoBonusTools.rhp “Rhino Bonus Tools” 8.1.23325.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.1.23325.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.1.23325.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.1.23325.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.1.23325.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.1.23325.13002
