Bug? Property Material not showing on 2nd monitor
Rhino is on the main monitor and Property window is on 2nd monitor. Properties-Material won’t show the list of materials. When clicking the down arrow, nothing happens. I have to move the property window to the main monitor, then it will show the list of materials.
The separate Materials window doesn’t have the same problem. Is this a bug? Or there’s hopefully something I’m missing, and it can be fixed?
Hello - please run 'SystemInfo` in Rhino and post the results.
So far this seems to work as expected, here.
system info.txt (2.8 KB)
Here’s system info.
Thanks for looking into it.
Hello - does it make any difference if you disable Enscape in Options > Plug-ins page, and then restart Rhino?
Not sure if it was RDP issue? It’s working fine now that I use VPN.
Yes, this is driving me crazy also,
On two monitors, the Material Editor Window moves outside the monitor resolution area, and the only way to have it accessible again is to switch between duplicate and extend monitor in windows display settings.
Please fix!
Thank you!
On two monitors, the Material Editor Window moves outside the monitor resolution area, and the only way to have it accessible again is to switch between duplicate and extend monitor in windows display settings, so the position will reset.
Please fix!
Thank you!
Hi Bogdan -
Is this limited to the Material Editor Window?
ScriptEditor might have the same problem, but that window shows in the windows taskbar so I can pick it from there. Material Editor doesn’t.
