BUG: PointsOn repeats if F10 is presed tiny bit longer
Pressing the F10 key super quickly runs the ! _PointsOn command once. However, when I press the F10 key for a slightly longer period, it repeats the ! _PointsOn command. I consider this a bug, because it’s a highly unwanted action, a very irritating one. It repeats the ! _PointsOn command by accident, which forces me to press the Esc key quite often to cancel it after I already have the control points of the desired surface(s) on.
Putting the ! _PointsOn command inside the list of commands that should not be repeated does not help in this case. Rhino options > General > Never repeat these commands.
The issue is even bigger when I use one of my mouse’s custom buttons assigned to execute F10. For some unknown reason, it runs the ! _PointsOn command twice even if I hold the button less than holding the actual F10 key on my keyboard. To run the ! _PointsOn command once with the button of my mouse, I must press it and release it really fast.
If I press and hold the F10 key (of the custom button of my mouse) for a longer time, it runs the ! _PointsOn command gazillion of times.
do not repeat affects Enter/ space / RMB
In Rhino 9 however, I don’t see the command flashing repeatedly like in Rhino 8.
Holding a key repeats it, but that is rather general keyboard behavior, I’d say. I’m sure you can change this delay in your Windows keyboard settings.
