record streak goes on.
there is nothing else to explain that the topic name and the picture, those are points which are not clipped which are part of blocks.
Gijs
(Gijs de Zwart)
September 9, 2024, 4:55pm
2
Hi @Juan_Gallo ,
I could not reproduce this with a simple test on my end.
can you provide _SystemInfo and a sample file that shows this behavior?
ivan.galik
(Ivan Galik)
September 9, 2024, 5:40pm
3
maybe in 8.12 it is not an issue anymore
Hi all -
I think this is a bug?
I’m using a clipping plane with a set depth (LOVE this feature of R8). It does a great job clipping away most of the geometry (point clouds, surfaces, curves), but for some reason, points that sit behind the clipping plane are still visible. Surface control points show the same behavior.
On the attached images, I would expect to see only the green point, as it sits on the same plane as the clipping plane. In the clipped view one can still see the red point, alo…
