Bug Points are not selected in the Align Mesh Vertices command
Hi
@BrianJ
@tim
@dalelear
This command will not be selected when turning on the points… Is this a bug? Because it works on mesh
bug.3dm (136.5 KB)
Hi
Bug?
AlignMeshVertices: Supports SubD
https://mcneel.myjetbrains.com/youtrack/issue/RH-57183
Thanks, filed as https://mcneel.myjetbrains.com/youtrack/issue/RH-57497
Hi @BrianJ
Works well in mesh but does not work properly in subd
bug.3dm (175.0 KB)
Thanks, filed as https://mcneel.myjetbrains.com/youtrack/issue/RH-57826
