BUG Pipeline R8
I’ve encountered a bug with the pipeline and finally managed to replicate it.
If a brep in Rhino has some textures once you select the type of geometry to filter (point, curve, brep or mesh) the pipeline crashes:
If the textures is removed the pipeline continues to crash and it seems there is no way to make it work.
The same files seems to work with the pipeline in v7 but to crash in v8.
The only solution I’ve found is to save geometry only and restart.
I’m using Rhino 8 SR4 2024-2-13 Rhino 8, 8.4.24044.15001
@piac is this on your radar?
Hi
I know there have been SDK changes around texture mappings, so I’ll have to ask and look around.
Definitely that line of text is from V5 or V6 times, so, it’s strange that it started to print the error now.
I’m keeping track of this bug at RH-80456.
You’ll be notified of updates here. Thanks,
Giulio
Giulio Piacentino
for Robert McNeel & Associates
giulio@mcneel.com
This bug should be fixed in 8 SR 6.
