Bug ? - PersistentOnSrf not working in Copy command
I was expecting to be able to proceed to several copies with the Copy command and POnSrf. It only works for the first pick.
Also in R7, also for PonPSrf.
Also related to this, in French UI, almost all special OSnaps OnSomething or POnSomething cannot be called from the Tools menu. I get the “unknown command” error. I guess there is a missing underscore for that.
Capture d’écran 2023-07-28 143206
Yep, I see both of those…
https://mcneel.myjetbrains.com/youtrack/issue/RH-76079/Tools-menuObject-SnapOn-ObjectPersistent-on-…-object-snaps-are-missing-the-underscore.
https://mcneel.myjetbrains.com/youtrack/issue/RH-76080/PersistentOn…-object-snaps-do-not-work-with-Copy
RH-76079 is fixed in Rhino 7 Service Release 32
And RH-76080 is fixed in WIP.
Thanks !
