even more so when i subselect an edge this has been bugging me for a very very long time.
once i close the panel or simply open a different tab in the panels for instance display, the lag disappears entirely. also when nothing is selected navigation works smooth. but copying or moving objects becomes a battle, also navigation stutters significantly. i am currently using a macbook air m4 with 32 gb ram.
i have a file that i can share but not in public. but that actually happens on other files either. it just seems it rather happens on bigger files rather than on smaller one that are in the mere beginning.
If possible, use Rhino3d.com/upload and send in that 3dm as well as the SystemInfo results from your Rhino. Note this Discourse post on the upload comments please and say it’s for me BrianJ. I’ll take a look and get it filed for the developers. Thanks
Hi did you solve this? I’m thinking about buying an M5 MacBook which is similar to yours and your comments got me worried.
I use it for architecture and my file sizes are usually 1-200mb although they can get up to 4-500mb in extreme cases. I don’t like navigating in wire frame and typically use rendered mode. Could you share your experience so I better understand what I’m getting myself into?
