Bug or not? Inability to change the RMB command
I found that I can’t change the RMB command of the “Curvature analysis” icon. I can, however, change the RMB command of other icons, including the secondary “Curvature analysis” icon located inside the linked toolbar named “Surface Analysis”. Is that a bug or some new feature to lock the modification of certain icons that I don’t understand?
Looks like a bug to me, you should be able to change anything. I’m not sure why it’d work for one but not the other :thinking: .
Can you run OptionsExport and drop that here → https://www.rhino3d.com/upload?to=callum@mcneel.com
I’ll see if I can repro with your settings and then create a ticket.
It’s great that this icon could be customized in the future. I use the RMB to run the “Zebra” analysis.
I just sent my exported settings to your e-mail. :slight_smile:
Ok I’ve managed to reproduce it using your settings. VERY weird. The tooltip is also not related to that button macro either. Fun!
As I didn’t comment it before, YT here : RH-96233 Cannot change RMB command
Thanks for taking this seriously! I’m a heavy customization user and plan to make my commercial final version of Rhino 9 very different from the stock version. I use very little customization for the WIP to prevent all the crashes that I expected with my settings imported from Rhino 7. I reported these in a few topics in the past weeks.
Are you importing using OptionsMigrate?
I imported them from the top bar’s text menu Tools > Import options. I’m not at home and I can’t check now, but the menu should be something like that.
