I’m loving the new single window interface.
I have noticed that the first time I try to use the object properties popover window it is blank (as if no object is selected), even if I have an object selected. I have to deselect the object, then select it again and then the object properties popover works fine for the rest of the session.
thanks
Peter
Hi Peter,
Thanks for the feedback. Do you mean the right click>Object Properties choice when your mouse is over an object? If so, I am not able to reproduce this here so far. What are your system specs including OS and am I misunderstanding what you meant by ‘popover’… in my part of the world this is the name for baked goods something like a biscuit.
I can see the problem here: Brian, exit Rhino, Open a new one, make a box and with the box selected, click on the bagel at the top-right of the screen (single window mode) to activate the popover Properties panel. It is blank the first time it is used, claiming ‘no selection’.
http://mcneel.myjetbrains.com/youtrack/issue/MR-689
Oh… that bagel! I used the one in the right sidebar and also the pop up using right click both of which worked.
