BUG: Object Inspector Not Updating When Selecting Object (PRIMAL SCREAM)
I need to scream at the top of my lungs on this problem that has existed since V7 and I have complainted about several times. It did not exist prior to V7. That is, after running Rhino for a while, the Object Inspector does stops updating when an selecting a new object.
This causes the problem that one object is select while the properties being updated. I end up changing properties of object swithout even realizing it.
I have this problem on both of my computers.
I can generally force an update by changing to another window and going back?
How in the code does the act of selecting an object cause an update of the properties panel?
It would appear that this is not caused by a direct method/function call.
Is there some kind of message passing?
How is the control path for updating the properties panel different when selecting an object and when making a window active?
Rhino 8 SR24 2025-10-7 (Rhino 8, 8.24.25280.13002, Git hash:master @ bc93c2b33c9f4e914f7f64b6fb964f1013f94dcc)
License type: Commercial, build 2025-10-07
License details: Cloud Zoo
Apple macOS Version 15.6.1 (Build 24G90) (Physical RAM: 64GB)
Mac Model Identifier: MacBookPro18,2
Language: en-US (MacOS default)
.NET 8.0.14
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Apple M1 Max
Color LCD (1728 x 1117 @ 120.00Hz)
GPU Vendor: Apple
USB devices
None
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswift_Builtin_float.dylib
/usr/lib/swift/libswift_errno.dylib
/usr/lib/swift/libswift_math.dylib
/usr/lib/swift/libswift_signal.dylib
/usr/lib/swift/libswift_stdio.dylib
/usr/lib/swift/libswift_time.dylib
/usr/lib/swift/libswiftsys_time.dylib
/usr/lib/swift/libswiftunistd.dylib
/usr/lib/swift/libswiftDistributed.dylib
/usr/lib/swift/libswiftObservation.dylib
/usr/lib/swift/libswiftSynchronization.dylib
/usr/lib/swift/libswiftNaturalLanguage.dylib
/usr/lib/swift/libswiftMLCompute.dylib
/usr/lib/swift/libswiftDataDetection.dylib
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftSwiftOnoneSupport.dylib
/usr/lib/usd/libusd_ms.dylib
/usr/lib/swift/libswiftSpatial.dylib
/usr/lib/swift/libswiftPassKit.dylib
/usr/lib/swift/libswiftAppleArchive.dylib
/usr/lib/swift/libswiftVideoToolbox.dylib
/usr/lib/swift/libswiftGameplayKit.dylib
/usr/lib/swift/libswiftSpriteKit.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftMetalKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/usr/lib/swift/libswiftMapKit.dylib
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.24.25280.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.24.25280.13002
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.24.25280.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.24.25280.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.24.25280.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.24.25280.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.24.25280.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.24.25280.13002
/Applications/Rhino 8.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 8.24.25280.1002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.24.25280.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 8.24.25280.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.24.25280.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.24.25280.1002
/Applications/Rhino 8.app/Contents/PlugIns/SolidTools.rhp “SolidTools” 8.24.25280.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.24.25280.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.24.25280.13002
