[Bug] NullReferenceException after splitting a BrepFace
This is on SR4.
When I run the command as below on a simple surface drawn with the Plane command for example, a NullReferenceException ensues when getting the OuterLoop on the second face.
If I first convert the BrepFace to a Brep and then take the first face, the problem goes away. (see “uncomment this to …” in the code below)
    ObjRef sRef;
    Result res = RhinoGet.GetOneObject("Select a surface", false, ObjectType.Surface, out sRef);
    if (res != Result.Success)
        return res;
    BrepFace face = sRef.Surface() as BrepFace;
    if (null == face)
        return Result.Failure;
    Curve iso = face.UnderlyingSurface().IsoCurve(0, face.UnderlyingSurface().Domain(1).Mid);
    Brep splitted = face.Split(new[]{iso}, RhinoDoc.ActiveDoc.ModelAbsoluteTolerance);//RhinoMath.ZeroTolerance);
    BrepFace f0 = splitted.Faces[0];
    BrepFace f1 = splitted.Faces[1];
    /* Uncomment this to not get the NullReferenceException below
    f0 = f0.ToBrep().Faces[0];
    f1 = f1.ToBrep().Faces[0];
    Curve outerloop0 = f0.OuterLoop.To3dCurve().ToNurbsCurve();
    doc.Objects.AddCurve(outerloop0, new ObjectAttributes { ColorSource = ObjectColorSource.ColorFromObject, ObjectColor = Color.Red, Name="outerloop0" });
    Curve outerloop1 = f1.OuterLoop.To3dCurve().ToNurbsCurve(); // throws NullReferenceException
    doc.Objects.AddCurve(outerloop1, new ObjectAttributes { ColorSource = ObjectColorSource.ColorFromObject, ObjectColor = Color.Red, Name="outerloop1" });
    return Result.Success;
Another problem is that the first outerloop (which does not give an exception) is incorrect.
@stevebaer or @dale would you be so kind to shed your light on this? Much obliged :smile:
I’m looking into this right now.
Cool, thanks!
We found the bug; this should be fixed in SR7.
Excellent, thanks @stevebaer . We use the BrepFace object and its OuterLoop and TrimAwareIsoCurves method in one or our main algorithms. Glad to know that the bug is found and squashed :smile:
