V8 SR5
self explanatory picture
all edges should be grey …
can you post a file with steps to reproduce? You say self explanatory, but you’d be shocked how often we find simple solutions when we have a file and steps to repeat.
naked edges retain their colors (yellow in this picture) despite being set to inherit surface edge color settings which is set to grey. all edges should be therefore grey and no other color should be visible in the picture.
are you by chance using the showedges tool? If so what color do you have it set to?
I’m wondering if that tool is overpowering your edge setting.
hello, i am not using any special tool.
you can see naked edge settings work because naked edges are clearly red.
when you set those to use surface edge settings they should all be grey but arent.
Is the underlying object or layer color for this object yellow?
it is a by layer color and layer color is yellow. yes
