BUG Move hatch and internalize hatch
There seems to be a Bug when trying to move a hatch with the move component yielding: “Solution exception:Object reference not set to an instance of an object.”
As seen I’ve tried both with the hatch and geometry component but it doesnt work either way.
The hatch that they are referencing is a simple hatch of a square.
One additional bug cames up if trying to internalize the hatch.
I’m using Rhino 8 SR11 (8.11.24254.15001, 2024-09-10)
I’ll add that it seems to be a problem with SR 11.
I’ve tried the same thing (simple square hatch, move and internalize) on computers with Rhino 8 SR 7, 8, and 10 and it works.
I could not reproduce the error here in the latest internal builds:
I will install SR11 to see if I can reproduce
hi @Riccardo_Gon I could reproduce this in 8.11 and 8.12
If it helps I can send you an internal build (8.13) by pm
@kike @AndyPayne is this a known issue?
Thank you Gijs but i was just rearranging a general arrangement plan with a few (fortunately) hatches.
At the moment is ok without those few hatches or using other computers which are not up to date with SR11.
Yes. I fixed a bug with Hatches earlier this week and I think this is related to that.
This fix will be available on next 8.12.
