I found a bug with the new Spacebar workflow for adding components while drawing a wire.
The issue seems to happen specifically when starting a connection from an existing ‘List Item’ component.
If I start drawing a wire from the List Item output, press Spacebar, and select one of the suggested components that appears in the popup, the connection works correctly.
However, if I press Spacebar and then type to search for a component, the selected component is placed but the wire from List Item is not connected to it.
I attached a video showing the issue.
P.S. Not sure if the post category/tag is right.
BUG_List item + Spacebar search.gh (4.5 KB)
