BUG latest Rhino V7 version
It seems there s a bug when I try to dimension my layouts. Whenever I want to add a new dimension, it thinks I want to add a second dimension tagged to the most recent dimension added, a sort of continued dimensioning.
Thanks
Alexandre
Click on the “Continue=Yes” command line option and set it to No.
Well, that was easy.
Thank you so much. It never crossed my mind to check the command line.
Cheers,
Alex
If you do a lot of continuous dimensions, when Continue is set to Yes, there’s option for starting a new dim or continuing an existing Dim string:
Awesome, thanks a bunch
Alex
