Hi Team,
this is probably for @rajaa
I’m having trouble in getting a correct drawing from this 3D model.
The geometry isn’t perfect, I’ve pulled part of it deforming the main cylinder that’s probably the cause of the issue.
This is the B8 file:
20260325_SectionDrawing_bug.3dm (2.7 MB)
And this the V9:
20260325_SectionDrawing_bug_V9.3dm (3.6 MB)
And I get almost the same problem with part of the shape not correctly cutted, some of the shape of the cylinder not showing and more like you see here:
Hi skysurfer -
I’ve put this on the list as RH-94632 Section Tools: Failure Sample
