(where CuttingPoint1 & CuttingPoint2 lie in the domain of Outline)
gives me 3 curves. It seems like it is splitting the curve at the two supplied cutting points as well as the seam.
Additionally, if I try to move the seam to one of the cutting points:
rs.CurveSeam(Outline,CuttingPoint1)
and then run the splitcurve as above, the curve does not split at all.
For now I am able to get around this by using the TrimCurve function twice however this seems inefficient, especially when it seems like the splitcurve function should achieve this.
Am I doing something wrong with the SplitCurve function or is this a bug?
Once you have moved the curve seam to one of the split points, all you need to to is use the other parameter for a split point, although it should theoretically work with both as well… works here on my quick test…
Curves=rs.SplitCurve(Outline,CuttingPoint2)
or
Curves=rs.SplitCurve(Outline,[CuttingPoint1,CuttingPoint2])
Note: (I assume you know this) that SplitCurve() requires curve parameter(s) not 3d points. If you have points you need to convert them to parameters using rs.CurveClosestPoint(). Maybe that’s what’s not working?
I have played around with my code and I have noticed something odd. If I run the script as is, the curve is not split however if I move the seam to CuttingPoint2 and split at CuttingPoint1 instead, the code runs as intended.
Here is part of a mesh that I am working on (its an stl in the zip):
I have run into some problems with the split curve as well. It seems like it does not work with a list of parameters for the splitting location. (All parameters are within the curve domain).
I have attached the script I am trying to execute:
import random
crvs = rs.GetObjects('pick a curve', rs.filter.curve)
for crv in crvs:
t = 0
tList = []
while True:
t += (random.randint(1,6) * 466)
if t >= rs.CurveLength(crv): break
tList.append(t)
print tList
nCrvs = rs.SplitCurve(crv, tList, True)
for curve in nCrvs:
rs.ExtrudeCurveStraight(curve, [0,0,0], [0,0,2600])
Similar problem here, but it seems to be relative to Rhino 6
From my understanding, this function should output a list of curves. If N is the number of splitting points, the function should output N+1 curves.
Here is an example: ContourToSplit.3dm (580.5 KB)
And the code to test it:
ToSplit = rs.ObjectsByLayer(“ToSplit”, False)[0] # Domain of that curve is [0, 103.6]
split_param_1 = 5.88876429708
split_param_2 = 11.7775285942
split_param_3 = 57.7234327369
splitted = rs.SplitCurve(ToSplit, [split_param_1, split_param_2, split_param_3], delete_input=False)
In Rhino 5, that works. ‘splitted’ is a list of 4 curves.
In Rhino 6, that gives a list of only 3 curves. Looking at the objects, the missing curve is the first one; which should have [0, 5.88…] as a domain.
Yeah, one of the curves remains as a joined polycurve. Don’t know why. If you add 0.0 as a parameter to the list, the split succeeds with 4 pieces. @dale?
