Bug in Rhino 9 WIP caused by a custom display mode
I just noticed that there is a weird bug in the latest Rhino 9 WIP caused by a specific custom display mode that I have. The latter works perfectly fine in Rhino 7 and Rhino 9 WIP. Until now, when I tried a file made by someone else that consist pictures set as blueprints.
As soon as I use my “Bobi X9” display mode and switch to another mode (especially “BobiX14” or “Ghosted V3”), something like a screen-shot appears in the background…
Here are the display modes that seems to trigger the graphics bug:
Bobi X9.rar (173.0 KB)
Bobi X14.ini (13.9 KB)
Ghosted V3.rar (302.5 KB)
This is a modified version of “BobiX14” made by @Gijs a while ago, because the original one didn’t worked as expected in Rhino 8:
Bobi X14 adjusted.ini (15.4 KB)
EDIT:
There is a 2nd bug related to this file. Some of the surfaces became black while the “Zebra” is applied to them. What could possibly cause this? I sent the file to @Gijs.
I found a 3rd bug related to the display modes. When I open a Rhino 7 file that consists Picture objects (textures assigned to planar surfaces through the ! _Picture command) into Rhino 9 WIP and then save it from the latter as a Rhino 7 file type, the material type changes from “Picture” to “Custom”. I discovered this after opening the aforementioned file back in Rhino 7.
Even if I change the material type from “Custom” to “Picture”, the texture will no longer be visible in most display modes. It’s shown only in “Rendered” and “Bobi 1”. Every other standard display mode will not render the textures. Instead, the Picture objects are rendered as basic surfaces.
I already reported this bug in another topic 1-2 weeks ago, but I can’t find the topic, so I use this topic instead to report it again.
Another bug that I discovered is that certain photos that were used as a texture made via the ! _Picture command will be DELETED from the folder where I had it stored. Then I figured out that the photo was MOVED without any warning to a new folder names with the file name of the 3dm plus “_embedded_files” at the end. For example, one folder was called “T-6A Texan II - 8_6_2025_embedded_files” and I found the missing photo there. Why is this happening? I had at least 10 photos set as Picture objects in the file, but only one photo was missing from the folder and put inside that new “T-6A Texan II - 8_6_2025_embedded_files” folder.
Is there a way to prevent losing the visibility of the textures (made with the ! _Picture command) when a 3dm file originally created in Rhino 7 is then opened in Rhino 9 BETA, then it’s saved as V7 file type in Rhino 9 BETA? This happens quite often on my end and it’s frustrating. Check my post above for more information.
Here is another video where I show the issue with 3 layers, each consisting a plane with a texture. The first one works as expected, only because I was forced to create a new plane consisting the texture. The other two planes consisting a texture are properly seen only in a few select display modes such like “Rendered”, “Bobi 1” etc (only display modes that are set to render the material).
Before opening the V7 file in Rhino 9 BETA, all the textures were fine. Now the planes are “damaged” and fail to render the textures as expected, no matter which display mode is active.
